Post your sound bytes here.
not an A but mopar
7172duster
[/URL][/IMG]
Man, that is one hot Sebring.
Outstanding 66340SEDAN!!
Sound good and I see you can keep it straight too.
First time I seen you and your 340 out having a good day
Congratulations on a great Sedan man:cheers:
definitely awesome 66340sedan! i have seen the 2 burnout ones before but haven't got sick of them at all!
when mine is back together i will do what i can for a sound bite.
Thanks guys! I will have some new vids soon! :burnout:
lets see if this works.....
nope. well, i have an "avi" file. i don't see it as a file i can download.
See if I can post this right. My son grabed the camera and shot this while I was under the car cleaning off a big *** black garbage bag (empty) that blew under the car while blasting down the highway, sucker stuck itself to pass side muffler, stunk like hell:snakeman: You can hear my neibours street hockey game in the back ground.....big kid LOL!!!
http://www.youtube.com/watch?v=jMHm3NsRqsM
Engine is 360, cam 280durr/474lift
Dont know if anyone got back to you on your cam but I tried the 508 for my cuda and my dad has the 509 in his GTX and we swapped both out for the edlebrock performer RPM its like a 484/510 i think. A way better cam for street driving. Still has tons of power.
Totally forgot about this thread when I got the little Valiant running.
Here's my combo
340 0.30 over 10.1:1
Ported J-heads Comp 292H .501@50 244 dur intake/exhaust
Mighty Demon 650 with 1" 4-hole spacer and Eddy RPM performer intake
2.5 inch TTI exhaust headers to Dynomax Superturbos with turndowns
Had a little exhaust leak and flooded the carb. LOL. I have not done much tuning to the carb yet.
http://www.youtube.com/watch?v=JWmj3s2l7Pk
7172 I just love that car. It launches amazingly and sounds great. What exhaust are you running?
The duster is 414 cid. small block stroker with INDY cylinder heads, the exhaust exits thru Hedman Husler headers with a hooker collector using a 3.5 inch flange , there is a 3 ft. piece of 3.5 inch pipe between the header and the dynomax bullets .http://www.youtube.com/watch?v=UvhcjyMiMyU
511 CI stroked 400
400 Block
Comp Cam custom grind solid roller .631 lift in & exh, duration at .020 286 / 292 @.050 250 / 256 110 LSA installed at 105. Valve timing @.050 Int 19 BTDC 51 ABDC EXH 62 BBDC 14 ATDC. (spings installed to match 210 seat pressure with 10 degree locks)
Forged pistons 10.55 to 1 with 84cc eddy heads & .040" gasket
RPM intake
850 DP
-15cc dish piston. size 4.375
4.25 stroke with H beam rods
Zero deck
Crane roller rocker 1.5 ratio
TTI 1 3/4 headers
2 1/2" Pypes X pipe system with street pro mufflers.
http://www.youtube.com/watch?v=VvIAJmV3RMg
Figured I'd post a new video of Ruby.
1966 Plymouth Valiant Signet Hardtop
360 erson .510 solid cam
Open headers: Just got the Spitfire headers installed
Flowmaster mufflers not hooked up.
Engine size 318
Cam size 280H .480 int .480 exh 280dur. comp cams
Header brand and size 1 3/4 " tti stepped headers
Pipe diameter 3" exhaust to axle w/ drop offs
Cross over - X pipe, H pipe, none H- pipe
Muffler type and size 3" flowmasters 30 series
Tail pipes, size. none
sorry but I don't have any on idle quality but I will post them soon.
I can't listen to any from the put file site because I am limited to what I can do at work.
Uh, yeah... I just realized that there is nothing there Sorry!!
http://www.mopartube.de/videodetails.php?key=107282e0aca380ff6237
Engine size 345cui
Cam size small comp solid roller 242/248 @ .050 .570/.576 lift
Header brand and size TTI step headers 1 5/8"-1 3/4"
Pipe diameter 3" mandrellbent
Cross over none
Muffler type and size Apple racing mufflers 3" round body about 6x18" straight thrue
Tail pipes, size 3" turndowns right after mufflers under bumper
heres one of my old exhaust, just idling
