dodgegtdart68
Whats the best ?? Cheapest ??? And where can I get factory color silver for a 1968 Dodge Dart RIMS.
What, in your opinion, is wrong with stick on weights? I have never lost any or had a bad balance job in the 30 years of using stick on wheel weights.I would stay away from stick on wheel weights and go with Dyna beads.
Just my opinion. Dyna beads are small beadlets that are poured inside of the tire (tubeless or with tubes). Used them for years on Harleys because stick on weights (black or Chrome) are ugly on rims, and look cheap, again my opinion. No marks from tape on mags and no scratches from the hammer-on type. Same reason I don't use the same style tires from 30 years ago. It's an upgrade for me. The only reason we would put them on a balance machine was to make sure the rim wasn't bent or deformed as well as the tire. Line up the dot on the tire with the valve stem, inflate...done!What, in your opinion, is wrong with stick on weights? I have never lost any or had a bad balance job in the 30 years of using stick on wheel weights.
