65 Valiant Vert
Active Member
Got an MBM master cylinder and porportioning valve years ago to convert to a double master cylinder with discs front drums rear. I am trying to bleed the brakes, have the master cylinder bench bleeded but can't get any fluid to the rear brakes as the first to bleed is the right rear brake. The car has all new brake lines. Is their someone out there that could help. Do I need to get a vacuum bleeder to get brake fluid in the lines as they are new and the master cylinder doesn't push enough fluid when everything is new?
I also am going with Silicone brake fluid dot 5 as I don't want to ruin any paint. Thanks in advance for any help.
