[SOLD] power disk brakes
rtse440
Rating - 0%
0   0   0
Selling a complete Power Disk brake setup, restoring my 68GTS. Complete with power booster, upper control arms, spindles, rotors, calibers, and sway bar. $250. unable to upload pics, large bolt pattern
Located in Richmond Va
I'm taking setup to Carlisle in July. If anyone is interested let me know
big bolt pattern? Sell them to me. But because of high shipping less to ship as possible, just:
upper control arms, ( required for a conversion from SBP??? )
spindles,
rotors,
calibers,
Dust shield?
Caliper adapters?
Can you check freight cost to Germany? USPS might be cheapest...
Seller is nice guy. Here are some pics to help that were sent to me. They are small but you get the idea of what is there.
[/URL][/IMG]
[/URL][/IMG]
i would take it if condition is good. Especially for the spindles. So this set is complete for a swap to BBP from my SBP? Can you PM me to finalize it?
Thanks, Michael
spindles,
rotors,
calibers,
Dust shield?
Caliper adapters?
Not sure if you have local auto parts stores but it would save you on shipping to buy the rotors and calipers from the store and pay the core charge...
Will check what rotors costs here. In Germany is only one specialised shop.
So minimum required are spindles, splash shield, caliper with mounting hardware, UCA. If the rotors ok than add them. They cost I guess around 150 each here.
Hahaha, so it's nearly all minus brake booster and sway bar :-)
Excuse my commentary here but... The sway bar doesn't belong in a disc brake parts package.
Why ?
The disc brake conversion will go on any A-body. There are 2 totally different sway bars requiring totally different mountings to totally different K members.
Your buyer could unknowingly pay shipping cost on a bar they cant possibly install.
Good luck to all.
Correct on the sway bar, it is a after market sway bar and does not use the original OEM mounting bracket ,was selling as a complete package. Sway bar does not have to be part of package
Why ?
Good luck to all.
without investigating I'ld say the sway bar doesn't fit a 72 K-Member. right? Can't be made fit? Calipers on this set are mounted in the front, I have to change sides anyway if I can have this set.....
grmpf, I'm too late. If the new buyer steps back or doesn't need all of it. I'm in need of
upper control arms, spindles, rotors, calibers....
