GoodysGotaCuda
Mr. Goody
Just looking for some comments, suggestions, tips on swapping my Power front discs for manual.
As it turns out I will need a new m/c, likely a brake booster as well to get the power brakes in my duster working. Thats about $100, and on top of that I don't really like the fact that braking is dramatically effected if the motor dies..you break it, run out of gas, etc. etc.
I've been offered the pushrod and retainer from a moparts member. The master cylinder is readily availible from any parts store.
As i understand it i will need to do the following.
Manual Disc Master Cylinder
Pushrod/Clip for manual brakes
Bend lines twords firewall some
Adjust the stop light switch
That sound about right? Only thing i've yet to quite understand is how the brake light switch would be adjusted for manual brakes.
THanks!
-Mike :thumblef:
THanks!
-Mike :thumblef:
