Power or Manual steerig Column ????
Dustedu2
Dixon
How can I tell if the steering column I have is set up for Manual or power steering box?
By length and coupler type. If you have either box on the shelf, see if it fits the coupler.
This is a picture of the shaft end. Can you tell by this if it's from Power or manual, I don't have a box to try it on. Thanks
That part of the column looks pretty much the same in a power or manual version. Measure the length of the section from the lower column housing to the end of the shaft.
Ok, will check it tonight. Thanks..
You can lengthen/shorten any of the collapsible columns. The real difference in power/manual columns is where the two halves are secured for total length.
Couplers are different
