Power rack/ exhaust problems
XtechX
Active Member
Edmore, Michigan
Is anyone using a flaming river power rack on your A body. I have one under my 68 fb cuda, its a 45" universal rack model number FR40020. I didnt install it in the car, it was in it when I bought it. It still needs an alignment to be completed, but seems to work well as it sits. The problem is the way the exhaust is routed currently. If you have a set up like this please share with me how your exhaust is run because mine is only sitting about 3.5" off from the ground. (I'ts just too low). My car has a 340 and a 4 speed and shorty headers. It runs straight down from the header, then loops under the power rack (with a heat shield on it, so it doesnt burn the rack) and then back up to the underside of the car and out the back right now. If you can visualize that?? I know pics would be better but I dont have any right now.
Any ideas on this would be great, if anything I've wrote makes sense. There just doesnt seem to be another way to route it because of the rack, starter, and bell crank etc. The passenger side isnt going to be easy either.
A picture would help but from the image I'm getting in my mind, wouldn't a set of full length headers work better? Say a set of dougs or TTi.
