power steering bracket
that is an earlier set up than what he is looking for. He needs the brackets for the pineapple shaped pump
The P/S brackets he is looking for, are to a Saginaw style power steering pump for year (He says 1977) and that would be a Saginaw pump. After looking around the shop, I have found that even some 73-74 model cars still used the older Federal style pump on some slant sixes. I think they did use both styles in 73-74 model years. We would have the Saginaw style pump brackets available, if any of the previous posters, cannot help you. Send us a PM, if you still may need them.
i have a 74 set up for a/c and the power steering pump/pulley isnt far enough doesnt sit far enough forward to line up with the outer most crank pulley. its a federal pump i think i just need the mounting bracket and pulley if the pump it self is different (longer pulley shaft?) im open to getting that. if its dimentions are similar to the one pictured here were in business:
