Just somewhere between the bottom and halfway up the neck
AND IT'S TIME FOR another story from the old days......
Years I ago I had a Meyer plow on the old FJ-40, and decided to use the PS for lifting the blade. I used a small double acting cylinder, which means that one direction it displaces fluid back into the system, minus the volume of the cylinder rod.
By filling the PS say, 1/2 from the top when hot, the thing would "use" fluid down to "almost too low" BUT IT WORKED!!!! And it was FAST!!! I put the valve between the pump and steering box, and the only time you lost boost to the PS was in the 1-2 seconds you were raising the blade
