Power steering for a 65 dart v/8
severn
houston
Hello,
I want to add Power steering to my 65 Dart GT V8,
any body have the set up for sale?
Thanks!
Wait a bit and should be able to get a setup for free by swapping your manual box and steering column. More people want to switch to manual for header clearance or for a big block.
If you piece one together, getting the column is hardest. For the power steering gear, get one from pre-1973. You need the TRW pump and brackets to fit your cast-iron water pump.
I thought all yo had too do was swap the steering box get an adapter for the steering column and add the steering pump!?!?!?
The manual steering shaft is longer than the power shaft. So in this case you would have to swap the shafts out....if I remember right.
I just went from power to manual a few months ago but everything is spoken for already.
