Wait a bit and should be able to get a setup for free by swapping your manual box and steering column. More people want to switch to manual for header clearance or for a big block.
If you piece one together, getting the column is hardest. For the power steering gear, get one from pre-1973. You need the TRW pump and brackets to fit your cast-iron water pump.
