Retnuh22
Questions for the group,
My 1967 Dart power steering box is leaking between the box and valve. I’ve researched here, and found that it’s probably a couple o-rings gone bad. Seems as though it’s a common issue or so. Question is... when I take the valve off, are there springs or valves that needs to be watched for as I pull it off? I’ve read I need to mark the valves location to make the adjusting that much easier. Any help would be great.
Also. Have a little play in the steering wheel while driving. I’ve replaced everything but the box. Is the box semi adjustable to tighten the play at all?
Thanks in advance. Oh and....Cheers!
