Fabbr
I picked up a rebuilt power steering gear box and when i was installing it i noticed the high pressure side had no provision for the hose to attatch to. Its female at the box and appears to be an inverted flare type of connection. My power steering hose on that end is also female. I picked up a double male inverted flare fitting and ran it into the box tight, and attatched my hose, all seems good, does this sound like it will work? or is the only way to know going to be filling it with fluid and trying it. Any thoughts or suggestions? Thanks in advance.
