that snap on puller is the best but there are 2 jaw pullers that are much cheaper that will work. 20 bucks or so. if you have the press on pulley a lot of them you can just thread a bolt with a nut and washer into the shaft as far in as possible, and use the nut and washer to press the pulley back on. you might have to chase the threads first wit ha tap. id also use a grade 5 or 8 bolt i tried it with a cheap bolt and sheared it off. with the right bolt it worked liek a charm. if you have the type with the nut on th eend of the shaft you should be able to get it on far enough that you start the nut and just tighten it up.
