[WANTED] Power steering pulley
John H.
Active Member
Cape Girardeau,MO.
Rating - 0%
0   0   0
Need power steering pulley for 1967 dart gt conv with a/c.
Don't know if it will help, but here's some info on the power steering pulley.
Chrysler part # 2128578 is pulley without AC, belt length from Gates is 39 1/8 inches.
Chrysler part # 2268665 is pulley with AC, belt length from Gates is 36 1/8 inches. Pulley with AC was used from 1963 thru 1968.
Might help if you could post the diameter and height of pulley.
Diameter is 5 3/8 Height is 2 1/4. Bore is 5/8. These are approximate. Checked with dealer and part #2268665 also was used on valiant and barracuda with 225 slant six with factory a/c
That is correct, all abodies from 63 thru 68 with slant 6 and ac used same pulley. Also all bbodies from 65 thru 68 with slant 6 and ac used pulley #2268665.
