Power steering question
First73Dart
Active Member
Levittown, NY
Is the piece over the pump with gasket supposed to be loose on the shaft or is it supposed to be connected to the power steering pump?
73 Dodge Dart custom
Thanks
If you are referring to the metal plate with the fingers, and the rubber gasket, they get crimped onto the steering coupler. Slide both down the shaft until it fits tightly over the coupler. While keeping pressure on it, crimp the fingers around the top of the coupler. Keep them tight as you do this or they will come off again.
Here's a file photo...
