I'm starting a full restoration on a 65 dart 270 convertible for my wife.
She's petite, so I'm makeing modificatons to make things easier for her, such as converting from a split bench, to buckets, which will make it easier for her to adjust.
The car currently has a manual top, I'd like to convert over to a powered top. I've noticed that the system used in 65 to lift the top really is not much different than the systems used on modern cars. The pump/rams for modern Sebring's seem to be readily available, and fairly cheap. If I fab the brackets, is there any reason I can't use the pump/rams from a Sebring?
Has anyone done a power top conversion with a modern pump/rams?
Thanks!
Thanks!
