I could barely hear it over the exhaust.
The Lock-Rite makes noise.
If they offer a "Powertrax" they redesigned it with a ring so that when the wheels are turning different speeds, it rides on this ring/ridge and does not click. It will give a small click or 2 once you get back straight as the locking mechanism engages.
You have to remove the ring gear to install on an 8 3/4. Reverse bolts hold the ring gear to carrier. Remove the cross pin, spider gears, and install the 4 pieces that make up the lock right. Patience with the springs. You need to run the 2" spacer dealymabobber (technical term) that goes inbetween the axles and over the center pin.
Good bang for the buck.
