Pre Bent Fuel Line and Sub Frame Connectors
scuba0331
Ohio
I was planinng on using pre-bent but due to the sub frame connectors it appears these line will not work. I would have to cut the lines to them through the sub frame and up to the engine.
What is a good solution?
I was thinking of using SS Flex line and fittings. How do I connect AN fittings to the stock sending unit?
I am not sure how to proceed?!
Been there. The frame connectors create a definite barrier to installing the one piece line. I cut mine, installed the pieces, and rejoined with a flared union.
Technically the stainless will outlast the regular. But when you consider the original lasted 30+ years...
Stainless is great but a little more difficult to work with and flare.
