pressure washer
Snake
Mopar Nut
Belleville Canada
after spending alot of time scrapping grease and dirt off the under side of the Dart its still not clean enough.has anyone had any luck using a gas or electric pressure washer to remove grease and dirt from the under side.sandblasting is out of reach for me.Any tips .thanks:cheers:
You might want to check out the local rental place for a hot water pressure washer. The hot water makes a world of difference when cleaning grease and gunk ... should rent for a bout 10- 20 % more for a day but believe me it will make a huge difference ...
I bought a Karcher unit also and wonder why I didn't sooner. It's a 2400 PSI with a Honda 6.5 engine and was delivered for under $300 off E-Bay. Find a good presoak degreaser and it will do the trick nicely. :cheers:
I have a cold water unit, works OK in conjuction with Gunk degreaser and scraping off the major grease with a putty knife first. As the guys said, I'm sure hot water would make a world of difference!
The easiest way is to buy a few cans of Easy-Off oven cleaner. Spray it on and let it sit for about ten minutes, then hose it off. Depending on how thick the oil / grease is, it may take a couple of applications.
