Hi every-A-body
After complete engine restoration I am priming my engine. I am getting oil on the drivers-side rocker shaft at #1 cylinder TDC with 65 psi. Can anyone tell me what would be the position for the passenger side-head? The oil channel is on cylinder #6, but as a rookie I don't know exactly to what position I have to turn the damper. Guess it corresponds with the valve-adjusting sequence. Thanks a lot. Robert
