There is a soldered resistor that connects between the power wire from fuse #5 to the ground side of the voltage limiter. The voltage limiter feeds power to the fuel and temperature gauges. The resistor is marked with a single red stripe which I'm at loss to decode from a color code chart. The resistor is marked 47Ω ±20%, 11 watts. Doing a little arithmetic that would mean there's a constant draw through this resistor of ~0.25 amps. The resistor on my piece is a dead short so I'm inclined to replace it but I'm not sure I understand everything I know. Can anyone confirm any of this?
