compared to what? you can spin the crap out of that 170, above 8 grand if its built... think you need to talk to Memike
You hit it 805moparkid, It's nothing to see My /170 low deck hit 5.500 rpm and be happy
I am sure his car is like mine and has 3.23 gears.
The 170 when tuned and set up with electronic ignition and remove the VERY small down pipe and all the exhaust and go to a 2 1/4 new exhaust with a quite muffle then add a 2'' tail pipe sure woke mine up and ran cooler along with getting 5 more miles to the gallon.
I think the main advantage is these 170/6 engines seem to tune up great and last a very long time compared to the long stroke 225/6 but I am just going by what I have seen and herd about the 225 throwing a rod some times #4 or 5 I think.
They put these 170/'es in combines to big generator packs back in there day, Farmers had them pumping water for there crops. But to say there is an advantage over the 225/ Charrie_S could say if there is or not, he elected to use the 170 for his /6 racer. Another advantage could be that the /6 head was designed for the 170/ not the 225/, all /6 heads are the same but maybe, just maybe they tune a bit better fir the 170/ :-k I don't know.
I can ell you this, they do not make a header for the 170/ not unless you can find a set of dutra duals. But in my opinion not unless you have a high revving racer these heads just don't flow that many numbers stock or even with big valves and a bit larger bump stick (cam). These early 170 and 225 slant six engines was built tuff and heavy, steel cranks and the same size bearings as a 426 hemi / 440 . later they went to a forged crank and smaller bearings.
Down side = less displacement (cubic inches), hard to find an automatic trans for these 66 67 170/'s. But I like my 170/ in my 66 Valiant sedan, just because these car's are very light 2.750, compared to the later A bodies that have 450 to 550 lbs they have to move around.
