Project Dusturbed
Soap Lake,WA/SanDiego,CA
Ok so Ive been trying to figure out what to do with my Duster. Then I saw a Dodge Demon on youtube and came up with this. Project Dusturbed.
Drivetrain:
6.1L Hemi bored and stroked to 7.0L (426 cubic inches) with supercharger
Tremec TKO-500
8 3/4 rear end with 4.10 gears and suregrip
Suspension:
AlterKation with QA1 coil overs
Street Lynx rear suspension kit with QA1 coil overs
Brakes:
Front-Wilwood 14 inch rotors with 6 piston calipers
Rear-Wilwood 13 inch rotors with 4 piston calipers
Wheels:
CCW Classics 18x8 front and 18x12 rear
Interior:
Mostly stock with a cage
This is what Im starting with. I plan on having it finished within the next two years.
18 inch rims? What's wrong with the set of rallyes already on it?
Sounds like a great build. Pretty much the same thing I'm after. Although I'm starting off with a 5.7L hemi.
Riddler
Well I've bagged the HEMI idea. I'm most likely going to use a small block now. I was goin through some old photos and found a pic of the car when it first hit my drive way with the /6 and 3 speed manual and 14 inch rallyes.
"Regular" SB's are nothing to sneeze at... Stout little engines... And AMAZING for strokers!
