ermarccio
I'm going with Wilwood's front & rear disc brake conversion and master cylinder. Should the proportioning valve go before or after the distribution block/safety switch? I like Wilwood's master cylinder with the prop valve attached. However, my concern is that having the prop valve before the distribution block/safety switch will affect the front/rear brake pressure and will trigger the safety switch...and thus my dashboard warning light which I'd like to avoid. Where do you guys place your prop valves?
Thanks,
Eric
Thanks,
Eric
