nashvegas99
Ok, I've got the feeling that after a battery and using a small jug to get gas to the carb continuously...i'll be able to get Rosey fired up enough to get the timing close and then hopefully adj the carb. After that, i'll drop the tank and get a new sending unit to install w/ 5/16 hard line from the back to the front. So, what are the thoughts of using an electric fuel pump, one of the universal ones, and block off the mech fuel pump when running a 225/6? My plan was to get a universal one and mount close to the bottom of the inner fender well and use the rubber line to get it to the carb w/ inline filter. A little down the road, but I like to think ahead. thnx
