Kenflo
Alternator, water pump, power steering pump and crank. I seem to have about 1/8" out on the crank pulley which is attached to an aftermarket fluid damper. So the power steering is about 1/8 out as well as the water pump to crank out the same amount. Is it ok to use washers behind crank pulley to got it aligned? I have grade 8 washers available.
