plumkrazee70
69 barracuda, 85 roller 318.
I have a 69 water pump, however I have the pulleys from the 85 motor, I can get the crank water pump and alternator to line up no problem. The trouble I'm having is I cannot get the power steering pump to line up.
It's currently occupying the space of the alternator drive belt.
I can move the alternator drive belt up one groove, however it doesn't appear that I can run a belt from the crank to the power steering pump, without the belt interfering with the water pump pulley. It's very close to the crank pulley.
I've never had a car with power steering before, amd this is an absolute nightmare.
I'm not sure why I'm having so many issues because all the pulleys are from the 85 motor, except for the 69 water pump is shorter than the 70 and up.
Can I run a long belt from the crank to the power steering pump over to the water pump over to the alternator? That would do it cuz they all end up with the same groove.
Attached are some pictures, any help would highly appreciated. I'm trying to get this thing running I just want to finish this part so I can move on to other things.
