Pulling under acceleration
scuba0331
Ohio
I have my 1974 Duster at the alignment shop and the mechanic said that it pulls to the right under acceleration. I'm not sure what it does that. Any thoughts?
It is a 360, 4-speed, with a B-body 8 3/4 with 323 suregrip.
jack up the front on the frame let wheel hang start up and see if the wheel turns that way my be in the box adj. if it power steering.other than that was the rear pads on the axle moved. might be a rear spring shackal bushing too.
Good info! Thanks,
The power steering did move on its own prior to sending it to the shop. But, I adjusted the valve and it stopped doing it. Maybe it's moving again i will see when I get it back.
Thanks for the help.
