SeattleQQ1Fish
I know this has been discussed before, but I thought I'd get some fresh perspective.
When I start the car, the voltmeter sits right on 13 for about 5 seconds. After that, the gauge flutters back and forth like a dog wagging it's tail. At idle, the voltage at the battery fluctuates between 13.9 and 14.6. In drive, giving it some throttle, the gauge still moves, but slower and fluctuates somewhat less.
I use the vr-128 voltage regulator and tried replacing it with no effect.
Alternator is a rebuilt 1966 unit, single field. Pulley is the same size as the 71 model I took off. Ignition is a MSD 6a box, msd distributor and Blaster 2 coil. Engine wiring harness is new from M&H, and I'm using Crackedback's wire around. Battery and alt. connections are all clean and tight. Grounds all look good. The battery is about a year old and measured 12.65 volts with the car off.
The engine is a 273 and runs good; I've never had any problems with it.
Could it be the alternator? Or maybe just ripple? I know rebuilt alternators sometimes have a bad reputation...
