Push Rod Question
Kendog 170
Let the boy go !
Tewksbury Ma.
I have a 440 with 440 source 500 stroker kit and stealth heads. I currently have a hydraulic cam , adjustable rockers with stock Ball/Ball push rods. Just a couple of threads showing after adjustment. I am switching to a solid lifter cam.
Now the question.
Will the push rods work or does anyone know what push rod I may need to order to go solid ?
You're the only person who will know how long the pushrods need to be. You'll also want to check the radius size in the new lifters to make sure it is the same.
