push rod removal
w2dodge
can some one tell me how to remove the push rod out of the seal from a master cylinder from a 69 dart .. using an rms 2 bolt m-c..and it says i can use the oringal push rod...
Just pull it out. It takes a bunch of force but it will come out. You can use the brake pedal to pull it out or use a bench vise and a pry bar or something like that.
Pull like hell. I yanked the piston and used a die grinder to cut it out. Here's some pics of what your up against.
Jim
thanks guys ...i just didnt want to brake anything..
