megavites
Measured up pushrod length with Comp cams checker. I have a .043 variance due to valvestem heights (stock variance is .030).
My plan is to go longer pushrods(all 16)…so that all lifters will get some pre-load on assembly (.006 to .050).
That will leave me with adding in .040 to .075 preload with the adjusters (Comp cam 1622 rollers) due to these
lifters needing btwn .080-.095. Comp tells me 1 full turn is .050-.060…the threads are 20TPI which comes out to .050.
so that keeps me 1 to 1 ½ turns approx.
This is all based on readily avail. pushrod length. I realize I could go custom length using longest measurement and dial less in w/adjusters.
Am I on course here?
