Hello, hoping for some insight on pushrod length. I have a 408ci I'm putting together with Morel Hydraulic Lifters, Cometic MLS head gaskets, Trickflow 190s, and Mancini 1.6 Roller Rockers. (block was decked .004).
I have the trickflow length checker and checked length on a few cylinders just to make sure there was consistency and they all measured out to 6.900 OAL factoring in a preload of .075. To get the BOC (ball to cup) measurement I subtracted .160 (half of 5/16") to get a BOC of 6.740
I could not find any installation instructions for the Mancini Roller Rockers but seeing as they are made by Harland Sharp I am using their installation instructions which recommends the adjusters be set so that 2 threads are visible below the rocker. I will call Mancini tomorrow to see if they have their own installation instructions. But, my pushrod lengths were measured with 2 threads showing.
Harland Sharp Installation Instructions: https://cdn.shopify.com/s/files/1/0569/2951/7720/files/7002K_Instructions.pdf?v=1630371422
I purchased a set of PRW 6.900 pushrods, thinking I was buying 6.900 OAL but they are BOC so after testing fitting them they are too long. The cup tip does clear the rocker throughout the full rotation of the motor, but its pretty close. Pictures below are of the PRW rods mocked up.
So my question, I guess, is: Does anyone have a set up similar to this and if so what did your pushrods measure out at? Also, what manufacturer did you use? (there seem to be very limited options for cup tip pushrods based on my googling).
appreciate any info that you guys have, thanks!
