I am going to ball to ball oil thru pushrods because I wasnt comfortable with the amount of oil getting to the pushrods via the shafts . And since this is a 7500+ rpm capable engine I would feel better with oil coming from both ends.
How does the adjuster position look to you ? This it at zero lash so it will be backed off another .020 once adjusted to run.
