T56MaxTorq
I have one pushrod that isnt spinning at all after a cam change on the Duster Broke it in with moly grease, zddp oil and some additive, 2500 varying rpm for 35 min. Took 3 tries to get there, never cranked and cranked..always started up fast. Runs and pulls good. Idle has a slight miss but maybe it's the cam..? MP 284/284 .528 solid flat tappet. 11-12" vacuum. It's too late tonight to do any measurements. I was going to do a compression check (it's #6 intake valve) Measure lift, and maybe run another pushrod. Should I really be worried about toasting that lobe?
