Hey Everyone, I completed a magnum head swap on an LA block last year and I needed pushrods. Mopar performance used to sell a set of 16 pushrods for the swap that were 7.625" long and have since been discontinued. I ended up getting a set of Manton pushrods from a member here at a good price. I am currently putting together another LA block with magnum heads and was looking for more pushrods. I found a set of Edelbrock hardened pushrods that will do the trick and at a pretty decent price. They measure 7.634" and sell for $59.00 at Summit racing. Edelbrock p/n 9656
http://www.summitracing.com/parts/edl-9656
Hughes engines also has a set that measure 7.640. p/n Hug 5268
http://www.hughesengines.com/Index/...aHJvZHM=&level2=T2lsIFRocm91Z2g=&partid=23734
Of course I realize that these may not work if someone is using a radical camshaft but with stock heads, standard felpro head gaskets and a mild cam both of these would work when I measured my engine for pushrods.
Just thought I would pass this info along in case someone else was doing the swap.
