SRT_DSTRHOLC
"There is never enough horsepower...."
Ok, so im about to put the motor together and I have a few questions I need answered.
Is it ok to use moly grease on the crank bearings and the rod bearings?
If so what type of moly grease is good?
Do i pack the oil pump with grease?
What can I use to prime the motor?
In what order do I install the Piston rings?
Do i dip the pistons into oil or put a little bit of oil on the rings becasue the how to build a mopar says dip the piston in oil so ask you guys...
and do I put the lifters in oil or moly grease on them?
