Fishy68: sorry i must have been thinking backwards
Mrpatel: i have thought alot about using a B-body gastank before,nice seeing that it seems to work right! did it fit with the stock A-body fillertube?
Fishy68: sorry i must have been thinking backwards![]()
http://www.pypesexhaust.com/gallery37.html
Here are photos from Pypes website, it looks like you'll have to cut the ends off if you want to use the factory style tips.
are the summit exhaust kits for a-bodies any good (the ones with and without mufflers)...i was looking into them since they seem pretty cheap....just wondering if anyone has any experience with them and if they are any good
i just finished installing summits 2.5" kit with a set of flowtech headers . headers were a PITA but the exhaust system fit pretty good . i had to trim the passenger side pipe off the header about 2" .i don't think that that kit will fit with the rear springs moved in though .
. I was just under the car yesterday and see the Pypes crappy stainless exhaust is already starting to rust. Less than 6 months on the car. Glad to hear your install went good.
alot of stainless exhaust that are cheap are cheap for a reason, they are kind of stainless. material is called 409 and is widely used in OEM applications, and is known to get a red/brown surface but will last a very long time.
in years past people sold and bought stainless of higher grade 304 as an example fully aware that they sold the good stuff.. then this thing "cheap" became very popular and alot of companys figured out that its almost stainless just not what people count on and since you cant make a lawsuit because of stainless that doesnt look like stainless they get away with it..
all stainless exhaust i make at work is 304 stainless,some people tells me that its expensive compared to brand X,W or Z or whatever i usualy just tell them that there is a diference betwen good stainless and the cheaper stuff..
Yeah I realize the differences with cheap stainless and good pure stainless. I've used 409 too and know it's not as good but I haven't even seen 409 stainless rust this quickly. And it is rust, not discoloration. After all the trouble I had installing this kit that was supposed to be a bolt on (with the normal mods to make it fit headers) it's just another straw on the Camel's back. I wouldn't recommend it to anyone.
nice seeing someone that knows the diference :cheers: wonder if there is something going on with what is sold as 409 steel i have noticed other brands using 409 rusting worse than they are suposed to aswell
sorry to hear that stuff that should be a fair bolt on failing to be bolt on![]()
