10.2 is fine by me. But I noticed the A/F ratio is a little lean at 13.2. I may try a jet change.
That could be, but a 1.56 60 ft at 10:20et is not the best.usually 10 flat is a good bit more than 130, unless its a NHRA class type car, from what i have seen.
Usually 130 is more like 10. 20 ish
Years ago my dart used to run 11.20 with a 1.50 60ft
10:20 should better than that.
Oh so you don't want the non destructive method.I already installed one and found that the oem one I removed was bent! Easy. No control arm removal required. Cut off wheel did the trick.
IMHO with nylon lower control arm bushings, the proper length is where you get the least amount of bind.The instructions are a little confusing. I'm hoping alignment guy can help me set the proper length. I do not have a 1/2 Allen so I'll go get one today. Clean the hole in the control arm before slipping the bolt through.
I have the Rms upper arms. Yes I recall that I had to do some trimming and notching. It said so in the instructions.Well now that the strut rods are installed. When I checked for front end travel, I found a problem. My QA1 Tubular upper arms are hitting the frame on both the front and rear. The front bushing tower can be trimmed. The rear contact area though is with the actual frame rail. I'm not sure I want to cut a notch and patch it. I see that everyone's Tubular upper arms are a straight shot to the ball joint. The arm should arch up at the bushing end to avoid the contact. The heim joint style look straight as well. Anybody run into this before?
I remember something about trimming if you needed to ,but the rear arm is laying on the frame rail. I can trim the front but it's the rear that's already hitting.I have the Rms upper arms. Yes I recall that I had to do some trimming and notching. It said so in the instructions.
I cannot comment on the qa1 model.
Got a picI remember something about trimming if you needed to ,but the rear arm is laying on the frame rail. I can trim the front but it's the rear that's already hitting.
Qa1 I have a set on my dartPsst, there are taller ball joints that raise the upper arm up. IIRC they are 1” taller?
That's sounds like it would solve the issue! Thank you! I'll look into them.Psst, there are taller ball joints that raise the upper arm up. IIRC they are 1” taller?
