Question about 74 dart front pillar covers
Nope, you need 2 door units. In the included pic you can see the difference. At the top of the 2 door unit at right you can see a longer flange with a tab that goes under the metal headliner trim, and the hole in it that you see is for the screw that holds the front of the headliner trim to pass through. The 4 door unit on the left just terminates at the top of the A-pillar, as the 4 door has no metal headliner piece and uses a different top trim!! All other details and dimensions are the same though!!Hope this helps, Geof
