ricks70dart
Working with stock point system, What would cause the coil to get so hot to touch and burn Distributor Lead off? The Coil is hooked up -- to Dist and + to batt.?
Posted this for friend.Says he figured out what the problem was the wire was loose on the Dist side of Coil ? ThanksIs your ballast resistor working properly? Hooked up?
