Patch
Patch
Hello all....I will be soon receiving a 1990 360 out of a pickup....I realize that this year (89-91) 360's are a lil different than the others.....but to what extent? I know it has a roller cam/lifters.....but the Mopar Performance engine books does not single these years with much clarity. Not a magnum, but not the same as the earlier ones. Other than the block being different for the lifter retainers....are the actual lifter bores longer than the normal LA engines? Can I put a regular hyd or solid cam set-up in it (not that I will...) Also....if I do run the roller cam, is it going to run like crap with a carb vs. the stock injection? Any pointers on this engine's quirks or pecurlararities would be great...Thanks in advance.....Pat
