Question on narrowing a 8.75?
BigClete
New Member
Lexington NC
So I've narrowed the rear frame to 24”. I was just wanting to ask I’m pretty sure someone has done it.
On my axle tubes do I need to keep the passenger side 1.5 less the driver side?
Or keep them the same on both sides so you can order same size axle for both side.
Feel free to chime in.
The centerline of the pinion does not change with narrowing so each side must be narrowed by the same amount regardless on the length of each side.
In other words, take the same amount off each side and that’s all there is to it.
Th motor is offset along with the center section but the way the axles set, they are the same length.
