Questions about 318 timing
Tuckerjr
Georgia
Hi guys,
I finally got a timing light and decided to check the timing on my 74 dart sport. It has been running and driving fine, but the gas mileage is really poor.
If I did it correctly it looks like I have 21 degrees initial and 15 degrees mechanical, is this correct? What, if anything, should I change? I checked the initial at idle and the total at 2500 rpms.
-Russell
Did it stop advancing at 2500?
Rev it til it stops advancing. If it happened to be 2500, great. Some mopar distributors don't stop until almost 4K.
I believe it's all in by 2500. I don't want to wake the neighbors so I will wait until tomorrow and double check. If it is all in at 2500 do I need to work on the distributor so I can run a lower initial timing and still have 36 degrees by 2500, or am I thinking about it wrong?
As crackedback said, if your all in @2500 with 21 initial, i don't think there's much mileage to be gained there. Is this a all stock 318? Might have to look at carb and exhaust to find some more MPG.
Set your total timming first (34-36) degs. Lock it down.
Now check your initial. Lets say it is 12.
Total timming minus initial timming. 34-12=22
This means 22 degrees of advance are built into your distributor. Lighter cars you want a quicker advance, while heavier cars you want to come in a little later.
Most small blocks work well with around 12 initial 34 total. All cars are built and run a little different. Street cars and drag cars will run different timming.
Now that I gave you some basics, you can find what timming works best for you.
VERY important if you might have a "stock" "smogger" distributor that has not been recurved, to REALLY wind the engine up to be sure it's "all in." Smoggers can have a very long slow curve.
If you aren't comfortable doing this, get the engine "barely warm" and unhook the fan belt. You won't hurt anything for the 1 minute that it takes to check this.
I just checked the timing on my 318 and as previously stated it was not fully advanced till 4,000 rpm. Vacuum advance disconnected the total advance was 20* from idle. The distributor is a stock electronic unit. I will be recurving it soon. Anyone have an opinion on the transdapt kit with the flyweights? Jegs has it for a whopping five dollars.
Probably just springs. The pictured stuff fits a GM distributor.
I always used kit's like that in the old days on many brands. Springs were the most important, very rarely used the weights. A dizzy machine is best, but hey, for $5.00 and play with it and it might get you what you need.
