jcmeyer5
Token Ford Guy
Working on sorting out the demons in the turn and braking system. Two things I am unsure of. First, I was under the impression that the flasher/hazard light switch was off in the center and on when up. Come to find that the switch mounts the other way, so it’s either down or centered. The dash lights come in when it is centered, and go off when it is down. Can someone confirm down is off and centered is on?
Second, I am trying to get the brake lights working. I have bypassed the switch, and I am trying to just get them to light up. Nothing is happening. I have 12v on the pink wire. Everything appears to be fine. The one thing NOT installed is the turn signal switch. From the diagram I have, it appears the turn/brake lights go through the turn signal switch. Would having it uninstalled cause the brake lights not to work?
Thanks guys!
Thanks guys!
