Quick connect steering wheel suggestions
o1heavy
1974 dart sport
tarkington
Looking for options
Wanting to use a quick disconnect steering wheel with the factory column
Correct me if I'm wrong
I have to use a adapter that will slide onto the splines which will then allow me to bolt on a 3 or 5 bolt pattern steering wheel ??
Looking for options
I use this set up. Not a "quick connect" per se, but it works pretty good and certainly makes getting in and out of the car over the cage and seat a whole lot easier!
Grant Anti-Theft Systems 2001
they make one you weld to the shaft for circle track cars
