quick thread question
diymirage
HP@idle > hondaHP@redline
michigan
found out today one of the boltholes in my 727 transmission is stripped
it is the one that the mount bolts to
pretty sure it takes a 5/8 socket
so, i got to go out and buy a helicoil set, but im not sure what size it is
The HEAD of the bolt and the THREAD of the bolt itself are 2 different things. A simple gauge from HD will tell you the size. Then determine if your thread is coarse or fine. (That is pretty obvious to see).
Your description needs to be more clear.
sorry about that
you know the transmission mount
bn:ANd9GcSE3w-aunAuYDWvta6FY9_LGJJX9E7cQyQupnqs95P86ldIOeCZsyfSpaMlv1mzYItR_9IFhHCcGEcn&usqp=CAc.png
(its upside down in this picture)
i meant the two bolts that go through the holes and mount it to the transmission tailshaft
(it does look like @Oldmanmopar answered my question allready)
i get that
i simply added the head size so you guys knew which one i was talking about
7/16 14 bolts have a 5/8 head.
Well, no, in Canada they have 16mm heads. A size never before seen in my toolbox until Canada forced me to buy one. You know, when we got bombed by the Metric System. But as you know. 1 of 16mm in your toolbox is never enough so I ended up with 4 new 3/8 drive sockets, 2 new 1/2 drive sockets, and a handful of wrenches. Boy was I a DA, 16mm is .6299inch, verses .6250 in standard. So all those 16s are languishing in the spares drawer, along with the 19mms and the 13s, and the 8s.
Yea. I hated to buy Metric tools as a young mechanic.
But, I had no choice since most US cars in the 80s started using metric. I remember the GM metric bolt heads were actually Blue.
My 1/2 inch wrench on the 13mm bolts only carried me so far, lol.
