Quick ?
AJ71DUSTER
Michigan
I bought a 727 trans pan gasket from the dealer today.info from a previous post thanks for the great info, i want to install it tomorrow, what are the torque spec for the trans pan bolts?
thanks for the help!!!!
According to a '68 shop manual, the 727's "Transmission Cover Retaining Bolts" need 12 foot pounds. :-D
I hope your gasket came with a new filter. Since you're dropping the pan, it's a good time to change it too.
Good luck!
Thanks for the info cudachick1968, i just put
a new deeper pan and filter on but the gasket wants to leak,so i will try
chrylers replacement gasket.
Thanks again
You are very welcome. Always happy to help if I can.
Leaks aren't uncommon. Use some RTV Black silicone too.
