Quickfuel metering blocks, anyone use them?
got them on two holley 750 dp with a proform main bodies..and billet base plate...everything works great.
Any idea which ones you used? I was thinking of getting the double pumper set 34-105 that has the timed vacuum nipple on the primary block and no PV on the rear, but the tech from Quick Fuel I talked to suggested the 34-4 blocks front and rear. Not much difference in price and I don't have the vacuum advance connected, so I'm leaning towards his suggestion.
